tbz
Good afternoon everyone,
Working on a set of drawings for a client and I have a question that seems to allude me as to why it exists and I don't see it commonly enforced.
A little background information; brand new small private office building for a single user, the building is only 2 stories, 1st fl 2,800 sqft, 2nd fl 1,900 sqft, 13ft fl to fl total rise.
Inside the first first floor there is an elevator that is used to go from 1st floor to 2nd floor.
Outside the building under cover is the MOE compliant stair flight for the 2nd floor.
However, inside the building in the corner is an interior NON-MOE designated stair flight, a convenience stair, again not the designated MOE. The stair flight is curved in one direction and no other treads, now for my question.
The Stair flight has an inside tread radius of 40.75" and an outside tread radius of 84.75". The treads are slightly over sized with 6.875" risers, thus they exceed the tread depth requirements at the required walk line.
Project is in Florida by the way: 2017 FL IBC
Now Section 1011.9 Curved Stairways. "Curved stairways with winder treads shall have treads and risers in accordance with Section 1011.5 and the smallest radius shall be not less than twice the minimum width or required capacity of the stairway."
Now to me winder treads are treads that go in different directions, like making an "S" turn or straight treads and then curved treads and the definition of "Winder" in chapter 2 of the 2017 Florida IBC reconfirms part of this with "A tread with NON-Parallel edges."
Well on a curved stair the radius edges are parallel but the front and back edges are not, as they go out in a fan tail pattern.
Now the current design and flow has the inner tread surface over the minimum required on a large radius stair with the same requirements and thus I am trying to verify how 1011.9 does or does not affect this stair flight.
For the record, I looked at a spiral stair definition and it notes it has a center column, so whether you can have a tighter radius is solely based on column being present?
I am looking for insight to see if I am over thinking this or is my question just in that a spiral stair can be real tight, but a curved stair can't be less than twice the width at the inner radius even with larger stair treads to offset a tighter radius at the walk line.
How do others read section 1011.9 and apply it to a single direction curved stair with no straight treads, same direction and uniform size treads for the complete stairlfight, top to bottom.
Look forward to your responses - Regards Tom
