Dazed and confused
peesncues
Colorado
Occupancy separation question-
2006 IBC, Third printing, Table 508.3.3
Why does the code require a 1 hour (or 2 hour for non-sprinklered) separation between a B or M occupancy and an S-2, but no separation between a B or M and S-1?
S-2 is lower hazard, is it not?
This seems bass-ackwards!
Re: Dazed and confused
Yes it does seem that way, however this has been beaten to death in the old forum, and I would recommend searching for it there rather than resurrecting it again here! Basically, B, M, and S-1 are considered similar hazard areas, thus no separation required. S-2 is a lower hazard area, as you pointed out. So far, so good. NOW, since B or M is a higher hazard area than S-2, you are providing separation between the high hazard area (B or M) and the low hazard area (S-2).
Clear as mud?
vegas paul nailed it, at least the theory behind it. Not everyone agrees with it, but that is what the code says. There was considerable testimony over this subject that spanned at least three, maybe four code hearings.
It's also been discussed on this baord as well, and yes it is to protect the S-2 from the B or M.
Thanks for the replies.
Still doesn't make much sense to me.
I guess if I just throw my shoes and a leather coat in the storage room I can call it S-1 and bypass the separation!
Easy, peasy, lemon squeezy.
Also, without any rating required the building design automatically defaults to non-separated use, thus the sprinkler threshold of 12,000 SF would kick in.......
When applying this to what VP states - Then that section would make (more) sense. The two hour separation would make a separate fire area.
peesncues wrote.
Thanks for the replies. Still doesn't make much sense to me.
That would be an S-1 ;)
