Dead ends
gbhammer
Mid West
The 2003 IPC
Chapter 2: DEAD END. A branch leading from a soil, waste or vent pipe;
a building drain; or a building sewer, and terminating at a developed
length of 2 feet (610 mm) or more by means of a plug, cap
or other closed fitting.
The 2003 IPC
704.5 Dead ends. In the installation or removal of any part of a
drainage system, dead ends shall be prohibited. Cleanout extensions
and approved future fixture drainage piping shall not
be considered as dead ends.
The 2009 IPC has the same definition in chapter 2, but does not have section 704.5. Does any one know why the ICC removed this requirement from the code, but kept the definition and the commentary explaining why dead ends were bad? :confused:
I called the ICC:o and apparently they felt that the prohibition of dead ends was a waste of time and money in large renovations:pitty, so they removed it and forgot to take the definition and revised poorly written:( commentary out. So never mind.:banghd
That's what you get for calling the ICC...a waste of time and money answer.
