I am asking for your opinion about the various terms used in the IRC to describe exterior walking surfaces: Deck, Porch, Patio, Balcony.
After 16 years of teaching deck codes and 10 years participating in deck code development, it is painfully clear that these terms are not used or interpreted consistently. I listened to testimony in the 2024 IRC hearings from respected professionals stating that because a certain code section said "porch" that it does NOT apply to "decks". Or if you are building a "porch" you would not use the "deck" section 507.
This makes ZERO sense to me.
Crazy as I am, I am already beginning to work on 2027 IRC proposals and dealing with this terminology is one of the lofty goals I am going after. I would like your thoughts and opinions of what these terms are and how they should be used in the IRC. Below are my thoughts. Please comment with yours.
Deck or Porch: From a code standpoint these are the same. "porch" is an older term. "deck" is a newer term. This is what my historical book collection has taught me. "porch" was often on the front of the house and often had a roof. Thus "porch roof" is also a common term. I see no need for the term "porch" in the IRC and believe all exterior, framed walking surfaces should be called "decks". If you disagree, please explain the "code implications" that should apply differently to porches than decks.
Patio: This term is less used in the IRC. I believe this is a walking surface created with materials that are supported entirely on grade. There are no structural applications from the code. However, should other code provisions for "walking surfaces" apply to patios? Such as safety glazing or stairs. What if a flagstone "patio" is adjacent to a 36 inch high retaining wall? Should guards be required when there is a "patio" vs when it's just grass? What do you call a "walking surface"? That's sort of another can of worms.
Balcony: I find this to only be different for structural design purposes. A "balcony" as might be commonly used to describe a small master bedroom deck is really no different than a deck, unless it is a fully cantilevered structure. I find the only reason to differentiate a balcony would be for prescriptive structural design purposes. I am bothered that historically balconies required a 60 psf live load. This was basically a safety factor of sorts for the concerns of the joists not being supported on one side. I find that a huge misuse of "live load". LIve load should be based on the anticipated loading by the occupant and nothing else. Occupants don't load balconies more than decks. What we need to do is create sufficient strucutural provisions to support a 40 psf live load on a balcony (cantilevered deck). That said, the 60 psf balcony provisions have been removed from the IRC a few editions ago. I still bring this up for discussion. The IBC and ASCE 7 require 1.5 the live load of the room served by a deck. So those documents already require all "decks" to be 60 psf in R occupancies. The IRC is still 40 psf and my opinion is that is sufficient.
I look forward to hearing your thoughts. Thank you in advance.
