Gary Cornelisse
I'm planning to lay my decking perpendicular to the house instead of parallel. I've been through the DCA 6 several times, and despite what our local code officer said, it's not clear how to figure out the specs for my beams and joists. Table 3 in the DCA is for joists framing from one side only. If my beams are extending from the ledger and I'm running joists between the beams (parallel to the house), it has to be framing from two sides of the beams.
I was hoping someone could point out the relevant sections of the DCA or help me figure out the necessary spec to meet code requirements.
- Basic deck dimensions are 20'x40', 40' side against the house
- Beams and joists will be 2"x10" Southern Pine
- 6"x6" posts at 10' and 20' from house
- 2 or 3 - 2"x10's" for a beam?
- Spacing (joist spans) between beams?
Any help is appreciated. Thank you!
