IMHO, Yesbrudgers said:If I modify a set of stairs to be code compliant does that count as an alteration?
What if the code compliant stairs lead to an attic?mark handler said:IMHO, YesAn alteration is a change to a building or facility that affects or could affect the usability of the building or facility or part thereof. Alterations include, but are not limited to, remodeling, renovation, rehabilitation, reconstruction, historic restoration, resurfacing of circulation paths or vehicular ways, changes or rearrangement of the structural parts or elements, and changes or rearrangement in the plan configuration of walls and full-height partitions. Normal maintenance, reroofing, painting or wallpapering, or changes to mechanical and electrical systems are not alterations unless they affect the usability of the building or facility.
I knew you would go there :beatdhrsbrudgers said:What if the code compliant stairs lead to an attic?
Speaking of chapter 3. If I was doing a project under chapter 3 and wanted to replace windows in a sleeping room that were non-compliant in terms of EERO...under chapter 3, would they need to be compliant?mtlogcabin said:I knew you would go there :beatdhrsIf installing a code comlpliant stair then use 303.1 it is easier
Thanks, that's how I read it, but I didn't know if I was missing something somewhere else...much like how I missed in the IFC that it referred to a "new building" for sprinklers (from the old threadmtlogcabin said:yesalterations to any building or structure shall comply
with the requirements of the International Building Code for
new construction
