Welcome to the new and improved Building Code Forum. We appreciate you being here and hope that you are getting the information that you need concerning all codes of the building trades. This is a free forum to the public due to the generosity of the Sawhorses, Corporate Supporters and Supporters who have upgraded their accounts. If you would like to have improved access to the forum please upgrade to Sawhorse by first logging in then clicking here: Upgrades
From the 2018 IRC, Ch. 2 - Definitions: "Wall, Retaining - A wall not laterally
supported at the top, that resists lateral soil load and other imposed loads".
The 2021 Oregon Residential Code has a definition for retaining walls.
"WALL, RETAINING. A wall not laterally supported at the top, that resists lateral soil and other imposed loads."
"WALLS. Walls shall be defined as follows:
Load-Bearing wall. A wall supporting any vertical load in addition to its own weight.
Nonbearing wall. A wall which does not support vertical loads other than its own weight."
However... the State of Oregon's Building Codes Division issued the following Interpretation in 2014: Interp-14-03-retainingwalls.pdf
"Retaining walls. Statewide, retaining walls that provide safeguards for the users of the buildings, support a regulated building or retain material that, if not restrained, could impact a regulated building shall require a building permit. A municipality may adopt an ordinance to regulate other retaining walls, provided that the threshold established for requiring a permit does not include retaining walls 4 feet (1219 mm) or less in height, when measured from the bottom of the footing to the top of the wall except where the retaining wall supports ascending slope exceeding 3:1 or where the retaining wall supports a non-soil surcharge. A local height threshold greater than 4 feet (1219 mm) is allowed."
