Definition of "Stemwall"
Saw one definition from a concrete website.
"Vertical portion of a foundation wall or retaining/restraining wall."
I would say that a stem wall is a short wall added to another wall.
From the internet:
Stem walls are supporting structures that are utilized as a means of joining the foundation of a building with the vertical walls constructed on the foundation. The wall is often constructed with the use of concrete and steel, and works with the foundational slab to create a solid basis for the building. Along with establishing foundational integrity for the building, the stem wall also aids in minimizing damage to the materials used to create the vertical walls.
I usually think of a stem wall (1 or 2 words) to be a short masonry or concrete wall extending from the footing to above grade and supporting a wood framed wall above. The code issue is that a hinge is created where the 2 join. It's not much of a problem if they join just above grade in a non-seismic or hurricane area, because the soil will restrain rotation of the stem wall, but it could be a problem if they join close to mid-height of the total wall.
The IRC is full of stem wall (foundation wall) requirements. I concur with Pauls definition
see FIGURE R602.10.7
MASONRY STEM WALLS SUPPORTING BRACED WALL PANELS
Sorry also, yes welcome to the forum!
Glad you found us, it's great to have new contributors.
Excuse my manners. Yes welcome and I notice you are in S Fl which is mostly mono slab construction from my years down there and stem walls where extremely rare.
A Stem Wall; Knee Wall; Segmented Wall;
By any other name is a reference to a wall that
supports a vertical structure load
that is UN-Supported in the lateral direction at eiter the Top / The Bottom ; or both
EG crawl space wall without a floor slab (supported at top by floor but not at bottom)
EG Half height wall (like your leg knee in the middle)
latterally supported at the bottom by a slab inside and earth outside at the foot (like your foot)
then continues up to the knee as a foundation (CMU or Poured Conc. or Lego Styrene, or Wood.)
then continuing up from your "Knee" to your hip which is latterally suppured there by a floor,
So Latteral support at the Foot by slab and at hip by Floor but the knee / hinge has no lateral suppurt
thus the so called knee wall - stem wall - wall segment - whatever it is called requires lateral support
at the knee / hinge / transition of construction type wall..
@ Arch1281 - 'lego styrene'? You wouldn't be alluding to ICF would you? LOL
DAEnglehart - Welcome aboard. Agree with the above (general) consensus. Appreiciate Ach1281's analogy as well... ;-)
True, but if the lot is low, and/or in a flood zone, then they use stem wall foundations to save the expense of fill dirt.
stemwalls usually mean crawlspace not basement/habitable space OR a walkout basement. Don't overthink what they are doing; if they need to dampproof the basement/crawalspace they need to do.
Sorry, late to this conversation. I've heard the term "stemwall" applied to a concrete curb of about 6" -8" height that is used at the base of exterior walls at slab-on-grade construction, to keep the wood-frame wall's sill plates from getting too close to ponding water on the exterior finish grade. This is especially helpful near accessible entry doors, where the exterior paving is almost the same level as the interior finish floor. In California, I've heard the LA Unified School District requires stemwalls in all their public school construction.
Interestingly, because the stemwall/curbwall is considered part of the foundation, it usually isn't considered by most local building officials as requiring the same insulation rating as the wood walls.
Neither the FBC-B nor the FBC-R define the term.
My definition: The vertical portion of a foundation from the building footing to the building floor slab. It is a load-bearing wall by definition.
