LGreene
I know that the codes don't address every possibility, but as a manufacturer we need to make sure that our products meet all of the requirements that a code official might establish, especially when the codes leave something up to interpretation. I have some questions on your interpretation of the delayed egress requirements. Some of the questions are specific to California, but even if you are located elsewhere I hope you will give me your feedback. Here is the section from the 2010 California Referenced Standards Code:
1008.1.9.7 Delayed egress locks. Approved, listed, delayed egress locks shall be permitted to be installed on doors serving any occupancy except Group A, E, H and L occupancies in buildings that are equipped throughout with an automatic sprinkler system in accordance with Section 903.3.1.1 and an approved automatic smoke detection system installed in accordance with Section 907, provided that the doors unlock in accordance with Items 1 through 9 below. A building occupant shall not be required to pass through more than one door equipped with a delayed egress lock before entering an exit. Delayed egress devices shall conform to all of the following:
1. The doors unlock upon actuation of the automatic sprinkler system or automatic smoke detection system.
2. The doors unlock upon loss of electrical power to any one of the following:
2.1 The egress-control device itself.
2.2 The smoke detection system.
2.3 Means of egress illumination as required by Section 1006.
3. The door locks shall have the capability of being unlocked by a signal from a switch located in an approved location.
4. The initiation of an irreversible process which will release the latch in not more than 15 seconds when a force of not more than 15 pounds (67 N) is applied for 1 second to the release device. Initiation of the irreversible process shall activate an audible signal in the vicinity of the door. Once the door lock has been released by the application of force to the releasing device, relocking shall be by manual means only. The time delay established for each egress-control device shall not be field adjustable. For applications listed in Section 1.9.1 regulated by the Division of the State Architect-Access Compliance, see Chapter 11B, Section 1133B.2.5.
Exception: In facilities housing Alzheimer's or dementia clients, a delay of not more than 30 seconds is permitted.
5. A sign shall be provided on the door located above and within 12 inches (305 mm) of the release device reading: "KEEP PUSHING. THIS DOOR WILL OPEN IN 15 [30] SECONDS. ALARM WILL SOUND" Sign lettering shall be at least 1 inch (25 mm) in height and shall have a stroke of not less than 1/8 inch (3.2 mm).
5.1. A tactile sign shall also be provided in Braille and raised characters, which complies with Section 1117B.5.1.1, Item 1.
6. Emergency lighting shall be provided at the door.
7. Actuation of the panic bar or other door-latching hardware shall activate an audible signal at the door.
8. The unlatching shall not require more than one operation.
9. Regardless of the means of deactivation, relocking of the egress-control device shall be by manual means only at the door.
Here are my questions:
1) How loud does the audible signal need to be? Is it acceptable to have the audible signal field adjustable within a certain range?
2) Many delayed egress products have a nuisance delay / alarm, which sounds a short version of the audible alarm sound if you brush against the touchpad but don't hold it long enough (1 second) to start the 15-second timer. Is the short sound a problem - ie. could someone unfamiliar with the product think that the sound means that the timer has been activated and the door will unlock in 15 seconds (the IBC language says "push until alarm sounds", not "keep pushing")? When the timer is actually initiated, the audible sound continuous through the timer cycle.
3) Is the unlock time a total of 15 seconds (1 second to activate + 14 seconds) or a total of 16 seconds (1 second to activate + 15 seconds)?
4) After the 15-second timer is complete and the door is available for egress, the code doesn't require any notification that the status has changed. Do you think there should be some sort of audible or visual notification that the door can be opened at that point?
5) When the fire alarm sounds, the delayed egress device must unlock to allow immediate egress. Does the audible alarm on the delayed egress device need to sound during a fire alarm? (hopefully not - see #7)
6) On a pair of doors, does activation of the delayed egress lock on one leaf require the other door leaf to release as well?
7) The California code requires manual rearming of the device at the door, regardless of the means of deactivation. This means that after a fire alarm or power failure deactivates the device, someone has to go to each door and manually rearm the device, correct? Would a card reader next to the door be acceptable vs. a rearming method right on the lock?
8) Do you have any concerns about delayed egress locks used in compliance with the IBC?
Thanks for your help! I know these are a little painful!
[TABLE=width: 180]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[TABLE=width: 180]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
