Department of Justice (DOJ) ADA enforcement "sweeps" hit the West Coast.
mark handler
So. CA
Department of Justice (DOJ) ADA enforcement "sweeps" hit the West Coast. What you need to know now.
By Jim Butler and the Global Hospitality Group®
Hotel Lawyers | Authors of www.HotelLawBlog.com
28 June 2010
http://hotellaw.jmbm.com/2010/06/ada_sweeps.html
Hotel ADA defense lawyer with the latest update on ADA "sweeps" by the Department of Justice coming to Portland, San Francisco and elsewhere.
We discussed in earlier blogs that the DOJ is conducting in-depth investigations of hotels to determine whether they comply with the Americans with Disabilities Act or ADA. The investigations are called "sweeps" because they typically target all hotels in a given geographic area. One of the first notable ADA sweeps hit all the hotels in Manhattan's Theater District, where we actively assisted clients.
A few days ago, we were contacted by a hotel in Portland, Oregon that had just received an investigative survey from DOJ. It appears that a similar sweep operation is being initiated there. We have also received information indicating that an ADA sweep might hit San Francisco in the near future.
Here is what you need to know about the sweeps, how they can affect you, and what you need to do.
There is a lot of valuable information on Hotel Law Blog about ADA Defense matters. Just go to the top of the Blog home page, click the "Hotel Law Topics" tab, and then select the first item named "ADA Defense." You will see all the articles on this subject organized in reverse chronological order.
Exactly what does this mean to the lodging industry?
As discussed below, the new sweeps are a "warning shot" - something that all lodging operators should take very seriously, and they should start working NOW to be prepared for these investigations.
But this is only the tip of the iceberg in terms of what lodging professionals should be thinking of in terms of accessibility compliance. In this article and the next one, I will interview two of the Senior Members of JMBM's Global Hospitality Group® who lead our ADA defense practice for owners and operators.
ADA Compliance is an area where an ounce of prevention can be worth a pound of cure. If brought in early enough, we may be able to counsel on relatively few changes that could make an important difference to the investigation. Marty Orlick is one of the top ADA lawyers in the country, with more than 300 ADA lawsuits and investigations under his belt, and he is actively involved in defending hotels that are included in the DOJ's ADA survey. Jim Abrams, who retired as the President & CEO of the California Hotel & Lodging Association, has advised hundreds of lodging operators about, and written and lectured extensively on, all aspects of accessibility laws that apply to the hospitality industry.
What if I receive an ADA Compliance Questionnaire from DOJ?
Jim Butler: If I am the owner or manager of a hotel and get an envelope from the DOJ with one of its ADA Compliance Review questionnaires, what should I do?
Marty Orlick: First, take it very seriously! Get the questionnaire to the right person as quickly as possible. You want an experienced ADA defense lawyer to walk you through these deceptively simple questions. DOJ is surveying both hotel owners and managers, and the last thing you want is for this document to be sitting in someone's inbox while the person tries to figure out what it means and who should be dealing with it. Every question on the form has been carefully drafted to elicit important information about ADA compliance. The survey is specifically focused on identifying architectural and communications (e.g., signage) access barriers and, equally important, your hotel's ADA policies and procedures. It is very detailed. Completing the questionnaire will take time and careful thought.
Don't complete it yourself. Have an ADA defense lawyer review it and advise you, first!
Similarly, when an owner or operator brings us in immediately on receipt of the investigative survey, we can recommend a pro-active and cooperative approach that will stream line the process, and minimize the cost and disruption to business.
Jim Butler: Why can't a knowledgeable hotel professional answer the questionnaire? Why should a lawyer -- much less an ADA defense lawyer -- get involved?
Marty Orlick: Each question is designed to obtain precise information about complex, technical compliance with the ADA guidelines. The forms must be completed under penalty of perjury, so wrong answers could subject someone to criminal penalties or create other unfortunate liabilities. Your answers can also help you to clarify the hotel's accessability features, policies and procedures.
In this very technical, legal context, hoteliers are unlikely to understand the legal issues in answering these critical questions. Even lawyers are unlikely to understand the implications unless they specialize in ADA matters. The questions must be thoroughly understood from a "Standard of Compliance" perspective as defined by law.
The wrong answer to a misunderstood question can cause serious problems that could cost you dearly. And the fact that your hotel has spent a lot of time and money to make the property accessible to the disabled does not mean the property will be fully compliant with the ADA.
Simply put, this is too important to mess up. You want an ADA expert's guidance to do this right and avoid unnecessary problems.
Jim Butler: Give us an example of a question that could cause a hotelier problems.
Marty Orlick: Questions about guest rooms have to be answered with great care. The questionnaire will likely ask for a description of all room categories in the hotel, and the number of accessible rooms in each distinct room class, because the ADA generally requires hotels to provide accessible rooms in each class. The thing you have to ask is: "What is a "category" or "room class"? In answering the questionnaire, you should NOT list each marketing or price-point category, as opposed to room types that are actually functionally the same accommodations but have minor differences. If you did, you would create a problem. Your hotel may have many marketing-driven categories for rooms, but in actuality your rooms may simply be singles, doubles, queens, kings and suites.
For example, if you have typical guest rooms and upgrade some of them slightly, such as with an extra lamp, higher-end bath amenities and a few extra square feet, you may call them "suites" for marketing purposes. From a functional standpoint, these suites are no different than your normal guest rooms in terms of accessibility. Similarly, if rooms cost an additional five dollars per floor, but there is no difference between the rooms on the 17th and 18th floors, they should not be listed in separate categories for purposes of the accessibility questionnaire. You want to list on the questionnaire the fewest number of functionally different room types/categories, even if they are different than the types/categories you show on your web site for marketing purposes.
Jim Butler: Does the survey focus solely on accessibility-related building standards?
Marty Orlick: No. Not by a long shot. The ADA Compliance Review also specifically focuses on the hotel's written accessibility policies and procedures -- or lack of them. So, the ADA defense lawyer should ask you to start pulling together documentation. We need to review the written ADA policies and procedures that are provided to staff to see what they look like. Policies and procedure manuals should detail all the devices installed and all the processes the hotel has established for serving disabled guests.
Jim Butler: Give us some examples of what those policies and procedures should include.
Marty Orlick: Any hotel's written policies and procedures manuals should cover all aspects of its operations as pertains to disabled individuals and those who travel or are associated with them. This would include such things as:
How to easily identify which ADA compliant rooms are available when customers call for reservations.
Procedures for hooking up telephone "TDD" devices or smoke alarms for the hearing or seeing impaired, or any other specialized equipment needed for specific disabilities including repositioning furniture and guest amenities.
Procedures for the evacuation of disabled guests in event of emergency, and how to work with disabled guests who have service animals.
Procedures used to train and monitor how the reservations, sales and operating staff are trained in all these procedures.
Many hotels surveyed will likely have technical ADA barrier violations. Those hotels can do things the easy way, by working cooperatively, through its legal counsel, with DOJ to correct the deficiencies, or they can do things the hard way--by refusing to cooperate or dragging their feet. As we know from our experience in Manhattan, the latter approach will be very lengthy, costly, and difficult.
Simply put, this is too important to mess up. You want an ADA expert's guidance to do this right and avoid unnecessary problems.Jim Butler: Is there any problem in waiting for the DOJ investigative survey as opposed to being pro-active in this environment?
Marty Orlick: ADA Compliance is an area where an ounce of prevention can be worth a pound of cure. If brought in early enough, we may be able to counsel on relatively few changes that could make an important difference to the investigation.
Yesterday Manhattan. Today Portland.
Stay tuned folks. The Midwest and South will not be spared.
Seriously, what's really surprising is that these facilities have not been paying attention to these matters for almost 20 years. Did someone think that the ADA was just a fad?
