Dreamchaser
This should be simple for the long-timers here!
SFR = Group R-3
House is elevated on concrete pilings / all supporting exterior columns/beams are concrete
All floor systems are steel web trusses
Stairs between floor levels are wood
NO interior load bearing walls
All exterior walls are 12" thick ICF (8" core)
Exterior of exterior walls are covered in 3-coat stucco
All exterior decks are concrete and steel truss with underside covered in treated plywood then covered with stucco
Garage ceiling below is 5/8" type X gyp
Storage enclosure in garage is 5/8" type X gyp (for stair access / elevator)
Interior beams supporting the spans where needed are heavy red steel.
Interior columns supporting the red steel beams are also red steel
All undersides of floors are sprayed with fire-retardant spray foam open cell urethane.
Interior ceilings is planned at 1/2" gyp but could be 5/8" or 5/8" type X if it makes a difference.
Interior walls are 1/2" gyp
Interior walls (all) are insulated with R-13 or R-19 fiberglass batts where appropriate for size
Interior of attic is spray foamed and then covered with radiant barrier
Roof trusses are made of wood, covered with 15/32 decking, covered with peel-n-stick barrier and metal standing seam roof
What is the proposed building classification?
What could it be?
What would make it better/tighter?
Would steel studs in the interior make a difference in classification?
SFR = Group R-3
What could it be?
