WindowlessBuildingOwner
We're trying to work out a design, and our structural engineer (who is licensed to submit stamped plans) is trying to figure this out as well, but we can't seem to figure out the right solution. Could anyone help me figuring out this dilemma?
Age: 1880s
Height: Three stories
Dimensions: 15'5 x 120 feet (very narrow and very long)
Current layout: Doctor's office on ground floor, two completely empty floors above
Plan: Retail space on ground floor, four apartments above (2nd front, 2nd back, 3rd front, 3rd back)
Front facade: Windows onto street.
Back facade: Windows onto street.
Second floor: Closed in entirely by buildings
Third floor: Closed in one side. Other side has the potential to put windows into brick walls, looking out onto roof.
Consider the narrowness and length, how can we fit bedrooms into this that are up to code? Some questions we're running into:
- Bedroom egress: I don't see any way to have a two bedroom apartment that is up to code... At best we could have a one bedroom apartment, using the window at the front, and then a windowless living room and kitchen?
- Could we have windowless bedrooms, if we put in ventilation and bright artificial lighting? Are we required to still have a second exit out of those bedrooms? There's no possible way to have an exterior exit because there are buildings on both sides.
- Is there any exception for townhouses? Historical buildings? Surely there must be plenty of other buildings that are in the same situation?
- Could we have two bedrooms with walls that only come up two-thirds of the way, and then windows above that height, to the ceiling? So that the natural light from the living room shines through the two bedrooms? But if so, don't we still need an exit somehow?
- My friend has a one bedroom apartment on the same street, new building, and his bedroom only has one door, no windows, but a lowered wall (6 feet from the ceiling maybe), what makes that a legal bedroom? Or does he technically live in a studio?
- What if the bedroom had one door into the apartment, and a second door on the other side, opening up onto a communal hallway that goes to the stairs, which lead to an outside door. Does that count as an egress?
- Would it make a difference whether we have one or two staircases?
- Egress for the apartments: Currently there are only stairs on the back side of the building. Are we required to put in two sets of stairs, one front and one back? My understanding is that we're an R-2 building, and could have one set if we have a "smokeproof enclosure" and the front doors were within 20 feet of the start of the stairs? Am I understanding that wrong? https://up.codes/s/single-exit-buildings.
- Are windows from the third floor onto a second floor rooftop in any way an egress that might reduce the need for stairways in the front and back?
- Could the single stairway situation be grandfathered in, since there's currently only one set, on one side?
- There is a very large skylight in the middle of the building. What if we built an open shaft down to the second or even the first floor (nice feature for the retail store). And then we'd put bedrooms against that shaft, with windows. Like a miniature courtyard that's about 8x8 feet? Would that be a solution for at least one bedroom on each floor?
Thank you in advance for your advice, even if you can only address part of these questions, I would be most grateful!
Age: 1880s
