Distance between buildings on the same lot - Hollywood, FL
tonyflux
United States
What is the minimum distance between 2 residential buildings (single homes) on the same lot to maintain fire codes without having to make additional fire rating to buildings?
Lot is in Hollywood, Florida. Adding new house next to existing one.
Thanks
FL Amended IRC Section 302.1 requires 6-ft.
Note that you need 4-ft minimum between the eaves, 6-ft between eaves to avoid 1-hr on underside.
Thanks
Are you going to keep the existing building??
will this be a rental or in law home??
Thanks
First you have to comply with zoning which may have more stringent setbacks. Then I would look into the building permit requirements.
