Yikes
When you leave a building, do you have to call the exterior path “The Exit”, or can it still qualify as “exit access” if the distance is still short?I am attaching a 3D exit diagram image of a proposed 18 unit apartment building. At the 2nd floor, the occupants would exit into an open-air double-loaded corridor (with roof), then outdoors onto a balcony that leads to a 2nd floor patio. The exit path then goes back inside the building into a lobby that serves the patio. The it goes outdoors again, down an exterior stair. From there it goes past a parking lot and re-enters into a open-air corridor (or, worst-case, exit passageway) to the front yard / public R-O-W.So, I leave and re-enter roofed building areas twice: I leave at B, re-enter at D, leave at E, re-enter at G, and leave to the street.If “B” is considered the “exit”, I have a code problem with re-entering twice, correct?On the other hand, if travel distance is so short that B,C, and D could still qualify as “exit access”, then I’ve got no problem.
/monthly_2011_01/572953dff2cf0_codequestn.jpg.e3a5d8cd047ce4a5e309d624ec566599.jpg
