Yikes
When doing improvements on a public housing project, I see at least 2 "triggers" of mandatory accessibility improvements:
1. INSIDE THE DWELLING UNITS: This is purely scope-based, not money-based. You can spend $2k or $200k on dwelling unit alterations and neither triggers accessibility upgrades (other than the alteration itself being accessible per 202.3). However, the moment you substantially alter a kitchen or bath and at least one other space, then dwelling unit full accessibility gets triggered. See 202.4 exception #1.
2. OUTSIDE THE DWELLING UNITS: This is money-based, not scope based. You must provide a full path-of travel to the area of alteration, and spend at least 20% of the adjusted construction cost to do so. See 202.4 exception #8.
QUESTION: When you have alterations both inside AND outside the units, is the adjusted construction in 202.4 exception #8 excluding not only the cost of accessibility improvements outside of the units, but also all the costs of all altrations inside the dwelling units (because they are already scoped under exception #1)?
