stevesteve
I understand that ASTM E‐1399 specifies different movement class joints, that correspond with number and frequencies of cycles that the joint goes through during testing and also that on a UL listing, the UL detail will specify what Class movement it has been approved for, but what determines which class movement is required for joint systems?
I also understand generally that Class I is supposed to 'mimic' (for lack of a better term) thermal movements, Class II - wind loads, and Class III - seismic loads.
But is there actually any codes in the IBC that REQUIRE certain class movement? Or is this just a best practice and to be used by the architect for their information to select joint systems as appropriate? And if that is the case that it isn't required by the IBC, then why is it mentioned in the UL listings/testing at all?
