door hardware ?
BSSTG
Gold Member
Seadrift, Tx.
Greetings all,
Existing bldg being remodeled. Occ load 85. Use is a combined office and reception area that will also be used for social gatherings and the like. It's actually associated with a a large RV park. So I'm not sure if it's a Group B or A. I am assuming Group A being more restrictive.
My question is about door hardware. We have 2 exits both of which will be side swinging. In reading 1008.1.9 of the
'06 IBC, panic hardware is required on both doors. Am I correct?
thanks
Byron
Not requirEd on front door if they meet all parts of that section
What ibc edition?? Are you using
Then yes over 50 panic hardware require on A and E
With the semi exception of the main entrance
