No1) Is this urinal required to be accessible?
1) The urinal is not required to be accessible as per Exception #4 to IBC Sec. 1110.2 (below). Given only a single urinal is provided, accessible use is not required per the IBC's scoping.
2) The urinal pictured appears to be set low for accessible use (17" max per A117.1-2017 605.2).
Yes, I meant that they appear to have set the urinal at a lower height in an attempt at complying with the height limit for accessible use.Agree with no...There is no min. height though? Or did you mean set low for accessible use?
