door separation required in large outdoor terrace?
gnarkill283
New York
We have a large outdoor terrace on a 2nd floor - do we need to provide door separation distance of half, third, or none of the max diagonal of the space? The building is sprinklered and gets the 1/3rd exception inside but what about outside?
So how many sq ft
What is it used for?
What occupant load are you assigning it?
1/3 the overall diagonal because the building is sprinklered--you can't hang fire sprinklers from the air (and if you could, they wouldn't work because there is no ceiling to trap the heat; therefore, it wouldn't get hot enough to set them off).
Yes but they need to be lockable
Look to the future:::
From the Guru.
Propose as alternative design, if needed.
From the Guru.
Wait so you telling me these type of doors in this situation can't be locked based on current and past code? How can they be secured then? Seems like buglars could take advantage of this if they knew about it
YES
Modern designs and other, that is why the codes are finally catching up.
They are exits.
Use the accepted code change as a justification for a code modification per Section 104.11.
