Paul Sweet
Sawhorse
20 x 20 grille and 20 x 8 duct is only good for 800 to 1000 CFM.
Is your unit on a platform where
The return air moves from the floor,, through the fillter,, into the unit??
Kind of like this::;
https://ixquick-proxy.com/do/spg/show_picture.pl?l=english&rais=1&oiu=https://basc.pnnl.gov/sites/default/files/HVAC2284_AHUCloset-fig%2018-djb-01-06-15.JPG&sp=6a598fef253a5915a81e14a13fc87114
No, the unit is not on a platform. The challenge is that the unit is set back in the closet with storage space in front of it, so I don't think a platform would work well here.
Just wondering mine sets on a platform on the corner of a room/ hallway
Two sides have vents
I can add one more
I wonder why yours necks down so much, once you get to the actual unit
I tried to upload an image but looks like the site only accepts web links. The short answer is there is just not enough space. There are about 4 inches between the unit and the left wall of the closet -- this space is used for the return duct. Through that left wall is the building common space, so no expansion options there. There is no space at all to the right of the unit (it's up against the closet wall). I'm guessing they built the closet too small by mistake, and by the time they realized this, it was too late/expensive to fix.
You have to be a paying sawhorse to post pictures direct.
But if you can make it into a link
You can post the link. That tech is also above my kindergarten diploma.
Sounds like sacrifice some space or find the best way to add more return
Hopefully your ac guy told you the unit can get damaged by the way it is now, at least that is what my guy said about restricted return
Looks like the image didn't work. Here is the link: https://ibb.co/cUEtd6
Central return system sucks (pun intended) but it is the cheap way to do it, which makes it the common way (but so does a poorly designed duct system). You could try cutting a small return at the unit in the closet and in the door to get some more return air back...Are there gaps under the doors in all of the rooms? If there are supplies in all of the rooms but no returns, door undercut is important to keep from trying to "inflate" the room and allow the return to work....
That picture works
Stick a jack under it
Cut some of the duct off on top
Make some room for more return on the bottom
You will probably end up doing what Steveray posted from a cost standpoint. It's not ideal, but it does work.
Just to add to Steveray's post, another option is to add air transfer grilles between rooms and the hallway. Some people prefer this look to the undercut doors.
Hi,
I have a Ducane forced air natural gas furnace with sealed combustion (PVC intake and exhaust pipes that vent directly to the roof), and the system was installed with a very undersized return duct, resulting in low airflow. One option a contractor recommended to fix it is to remove the old return duct, cover the hole where the return air enters the machine with a filter, and cut a louver in the door of the furnace closet. This would allow the system to draw air from the main living space of the unit, through the louver, into the closet, and directly into the return of the machine through the filter (no return ductwork).
I think this would solve the low airflow problem, but is there any issue with drawing return air through the furnace closet? The combustion is sealed as I mentioned, but my concern is that if there ever were an exhaust leak, carbon monoxide could get sucked into the return and be spread throughout the house.
Would this setup be a code violation? I'm in Massachusetts.
Thanks in advance,
-Tim
Can you do this fix and also bring another return duct from upstairs??
Is your unit upstairs or downstairs ?
The unit is downstairs. I'd love to bring in another return duct from upstairs but there is no room (without considerable expense).
I was wondering about the idea of vents in closet door
Plus just an duct from upstairs that also dumps open, into the closet
Anyway you have your question answered
Plus some ideas
With your ac company get the best results you can
Hate to say might be a little trial and errror
