This might be worth reading.
HOW TO WIN CONFLICTS AND OMMISSIONS
WITH PLANS AND SPECS EVERYTIME
By
Anwar Hafeez
Anwar Hafeez is graduate civil engineer, who has personally supervised $1.4 Billion in projects like the
Washington, D.C. subway; Armed Forces Medial University; LAX Airport Expansion; San Diego
Convention Center; L.A. Central Library and other projects. These projects ranged from $250,000.00 to
$300 Million. Mr. Hafeez has settled over $170 Million in Change Orders/Claims. Mr. Hafeez has its
claims consulting firm for over 10 years, which helps subcontractors with preparation and negotiation of
claims; CPM Scheduling; Teaching Seminars on Project Management and Change Orders/Claims.
In order to deal with Defective or Incomplete or Inadvertent Errors in Plans &
Specifications, owners and their architects have put in provisions in the contract usually
in the General Conditions of the contract under the heading of “Order of Precedence of
Documents”, which is listed as shown below (similar language in other contracts):
n Contract between Owner and GC
n Special Provisions
n General Provisions
n Specifications
n Details on Drawings
n Plan Drawings
This means that if the contractor has a CONFLICT between the Plan Drawings and
Details on Drawings, then the Details on Drawings prevail. If there is a conflict between
the Drawings and Details on Drawings and the Specifications, then the Specifications
will prevail. The higher “Order of Precedence of Documents” governs or prevails. It is
sort of like a poker hand where 3 of a kind beats 2 pairs, etc.
This only works if you have a CONFLICT NOT AN OMMISSION.
CONFLICT is defined as the Details on Drawings show one thing to construct and the
Plan Drawings something different to construct. OMMISSION is defined as the Details
on Drawings show one thing to construct and the Specifications are silent and do not
indicate anything.
To illustrate this further, SDC & Associates’ client encountered a problem on the last day
they were waterproofing a hospital. The waterproofing subcontractor had completed all
his work on the project, which consisted of installing waterproofing membrane on the
footing and turning it up the wall, similar to the sketch shown below:
The inspector on the project told the sub that he did not follow the detail shown above.
This detail states that this is a TYPICAL TERMINATION DETAIL and small print
states “Powder-Driven Pin and Washer @ 18” O.C. through continuous anchor strip”.
The inspector told the sub that his work is not done until he fulfills this requirement.
The sub reviews the specifications and finds no requirement for installing a Powder-
Driven Pin and Washer @ 18” O.C. through continuous anchor strip. There is no material
specified for an anchor strip.
The sub writes a RFI whose answer is “The continuous anchor strip shown on the below
grade waterproofing details is a 16 gauge metal strip. Submit samples”.
When you review specifications, you should understand how specifications work as
follows:
· Section 1 – States Scope of Work and related Specification Sections
· Section 2 – Specifies the materials to be used on this project and submittal
requirements [Nothing specified that is in the Detail on Drawing]
· Section 3 – States Installation Procedures. In this case, it states to install the
waterproofing membrane in accordance with the manufacturer’s
recommendations
The sub goes to the manufacturer who is horrified and says : (a) NO! NO! NO! You
cannot follow this detail; (b) You want to do what? Shoot thru the waterproofing
membrane and damage it; © This will VOID THE 5 YEAR WARRANTY.
The architect states that this is not acceptable and that the manufacturer must provide the
5 YEAR WARRANTY. So, the manufacturer devised a method to install a 2nd layer of
waterproofing membrane to cover the holes created by shooting thru the waterproofing
membrane. The sub installed this additional work, having no choice to do so.
The sub’s Project Manager sent a fax asking for a Lump Sum of $15,000.00 for this extra
work, without submitting any back-up. This was rejected by the owner and architect
stating that “since anchor strip is shown on contract drawings it is part of your contract”.
There is other verbiage that deals with OMMISSIONS in the “Order of Precedence of
Documents”, one of these states that”If some thing is shown on the drawings but is not
in the specifications – it is part of your contract”. What do you do?
This is the basis of the denial of this Claim by the owner and the architect. Suppose, if
you have wood base shown in Room 101 and the owner states install wood base per the
contract. You simply say that since the wood base is not in the specifications, I do not
know the quality of the wood base to be furnished and installed and your architect was
negligent in not providing this information to me. Therefore, my obligation is to install
the cheapest wood base available on the market; pine wood base. The owner will
invariably say that they want oak or mahogany wood base and now you can get a change
order for the material difference between pine and oak or mahogany.
The second verbiage that deals with OMMISSIONS, states that ”If something is
specified in the specifications but is not shown on the drawings – it is part of your
Suppose the specifications specifies oak wood base and the owner states that he wants
you to install this and you argue that it not shown anywhere and you argue that you do
not have to install it. In order to prevail in this situation, you must explain what the
purpose of drawings is for, which is to:
· Do take-off of quantities for the bid
· See locations for installation of specified materials
You must explain that since the owner’s architect was negligent in not showing the
location of the oak wood base on the drawings, there was no way for you have taken off
the quantity needed to install. So, propose to give them 1 Linear Foot of oak wood base
and ask the owner where he wants it installed. By giving the owner 1 Linear Foot of oak
wood base; you have satisfied the contract requirements. If the owner wants you to install
more quantities, then you can get a change order for the extra quantities and work.
Now, getting back to the “Order of Precedence”, where is the CONFLICT in the
documents for you to enable to win the Entitlement for Merit of this claim. GIVE UP???
This was our challenge when we took over this case for our client about a year after the
work was performed.
The CONFLICT is between the Detail on the Drawing & the Specification, which is:
· Detail on the Drawing show a TYPICAL TERMINATION DETAIL and
anchor strip
· Specifications Section 3 under Installation Procedures, states to install the
recommendations, which has TYPICAL TERMINATION DETAIL, which
the sub followed and installed his waterproofing membrane by
Therefore, under the “Order of Precedence”, Specifications prevail over Detail on
Drawings. We explained this to the owner and the architect and we won the Entitlement
for Merit for this case, despite the Architect’s protests.
There is built in mechanism in the contract to solve CONFLICT problems; the Architect
and the Owner did not use it in this case and the sub being unaware of this CONFLICT
solving mechanism did not use it either. The owner problem here is that the Architect and
the Owner argued that this was an OMMISSION problem, when in reality it was a
CONFLICT problem.
We re-priced this change order from $15,000.00 to $52,753.01. When we won the
Entitlement for Merit, the owner wanted to pay the sub $15,000.00 which we rejected but
the $15,000.00 cost proposal became a thorn in our side, the owner offered us that
settlement at least 3 times. We told the owner that the sub’s Project Manager gave an off
the cuff guesstimate which grossly incorrect and that is the reason that this Project
Manager does not work for the sub anymore.
You need to price change orders in great detail, show the process step by step and price
step by step. Using this methodology, we settled on $40,095.24. The owner wanted to
keep the settlement below $40,000.00. I asked the owner, when they can pay us, the
owner said within 5 days and we settled on $38,903.67. When you get paid is part of
negotiations as well. The settlement could have been higher if we did not have to deal
with the initial $15,000.00 cost proposal; so never give off the cuff guesstimates.
Why were we successful?
· ENTITLEMENT FOR MERIT: Using the Order of Precedence of Documents
· QUANTUM: Clearer pricing
One last thing, how do solve CONFLICTS:
1. BETWEEN DRAWINGS AND DRAWINGS
2. BETWEEN SPECIFICATIONS AND SPECIFICATIONS
The rulings have been that the most stringent of two requirements is what you should
have bid. Sorry, can’t help you here.
If you have a problem like this where the reflected ceiling plans show 12 lights and the
electrical drawings show 8 lights, how many lights do I need to install? The answer is
12 BUT how many of the 12 lights are build able; according to the Spearin Court Case of
1918, when an owner issues a set of contract documents for bid, the owner gives an
Implied Warranty that these contract documents are not defective and are complete and
suitable for building a project. In this case, 4 of the 12 lights are not build able, since you
do not know what the conduit and wiring requirements are; what panel board are these
lights connected to and whether any of these lights are to be on the emergency system.
So, if you argue this correctly, you can get paid for wiring the 4 lights as a change order.
So, now go out there and solve all the drawing and specification conflicts and win
everytime.
To contact Mr. Anwar Hafeez, you can call him at (800) 732-3996 or E- mail at
ah@sdcassociates.com. To know more about his firm, SDC & Associates, Inc., sdcassociates.com.
