I am a consultant to Ceilume, manufacturer of drop-out ceilings with an UAPMO-UES listing. I would like to address several comments:
"over the years how do you know they will be replaced with the same listed tiles?" Ceilume offers a placard to be mounted above the ceiling or by the main sprinkler valve notifying future building owners or managers that ceiling panels must be replaced in kind.
"as a fire fighter I never liked the idea of a product designed to fall on my head." Agreed. Note, however, that thermoformed panels by Ceilume are very lightweight, less than 13 ounces per 24"x24" panel, and unlikely to cause an injury. They fall one at a time in response to fire spread, so it is not like an entire ceiling falls on you. As a flat panel, they sort of glide to the floor instead of "dropping". I suspect they are less dangerous than other, heavier ceiling products that can pull down an entire ceiling suspension grid.
"can't stand it when crap falls down the bunker coat from pulling celings" Agreed. See comment above about lightweight. And pulling mineral fiber panels is one of the dirtiest jobs around. Thermoformed panels do not release fibers when they get pulled.
"the ceiling tiles (meltaways) are expensive" Meltaway panels, such as those made from EPS foam should be avoided. Melting plastic does not belong in a fire. Thermoformed panels, however, are made from sheet vinyl that is Class A, Flame Class V-0, and has intrinsic fire-resistance. Exposed to fire, they soften, sag, and drop to the floor still in their panel form. Their cost is competitive with many other types of acoustic ceiling panels.
"replace tiles due to water spots" Thermoformed panels are impervious to water damage, do not sag or stain due to water, and do not support mold.
"would you allow the drop out tiles in a ceiling that also had sprinkler heads dropped below the ceiling?" Ceilume's IAPMO-UES listing deals with this. The hole in the ceiling panel needs to be 1/4" larger in diameter than the protruding sprinkler. Testing shows this allows panels to drop without gettin entangled in the sprinkler.
"Clips ... can't be used on tiles unless allowed in the listing" Right. Ceilume's IAPMO listing allows clips.
"Ceilume products can be painted before or after installation" WHOA! While they can, in general, be painted, it invalidates the IAPMO-UES listing, the surface burning classification, and other performance claims.
I hope this clarifies the issues. We have several white papers on our website, and will be glad to assist.
