lpiburn
Silver Member
Hello All,
I'm trying to find out if anyone has ever seen a drinking fountain that works for both wheelchair users and standing persons. The exception exists in IBC 1109.5.1 (I'm using the '09 version).
Best Regards,
LP
ANSI says that the outlet height is 36" MAX for wheelchairs, and 38" MIN for standing.No fewer than two drinking fountains shall be provided. One drinking fountain shall comply with the requirements for people who use a wheelchair and one drinking fountain shall comply with the requirements for standing persons.Exception: A single drinking fountain that complies with the requirements for people who use a wheelchair and standing persons shall be permitted to be substituted for two separate drinking fountains.
I can only think of two possibilities. A drinking fountain with two separate outlets on the same fixture, or one with an outlet that can somehow adjust to both heights. A little searching found this thread, but nobody mentioned actually seeing a real product that would work. The closest thing I could find on the internet would be something like this with a valve extension on one side. Those things are so wide you may as well just install a regular hi-low at that point. Any thoughts?Spout outlets of wheelchair accessible drinking fountains shall be 36 inches (915 mm) maximum above the floor. Spout outlets of drinking fountains for standing persons shall be 38 inches (965 mm) minimum and 43 inches (1090 mm) maximum above the floor
Best Regards,
LP
