kyhowey
Silver Member
To bury or not to bury? Do you allow the HVAC installers to lay the ducts on the joists and then have them buried in the insulation? Or do you have them elevate the ducts above the insulation so you can get full R-value of the insulation? I've read plenty of opinions on both sides and I'm trying to establish a consistent interpretation for our area.
The state HVAC inspectors have concluded that they will allow either. But they also say the final decision is up to the building inspector. The only drawback for burying the ducts I can find is condensation in high-humid climate zones. Kentucky is not in the high-humid climate zone, so condensation is not a huge problem. I do worry that the insulators will not add enough insulation over the ducts to keep it R-38 causing those areas to violate the building envelope.
My main concern is large supply/return trunks that run the length of the house and how you would insulate those areas. Thoughts?
