pt26
Supporter
Hi there, thank you in advance for your help.
The codes are so incredibly circular and unclear about when accessibility applies, and when it doesn't.
Let's consider a small 3-story multifamily building with no elevator. Say 4 units per floor. All units are single story.
A completely prototypical building with nothing irregular, for the sake of example.
Under Ch. 11A, I understand that the upstairs floors are not "covered."
Then do we truly understand that to mean, the 2nd and 3rd floors of such a building are 100% exempt from ADA?
And how does this intersect with IBC Sec. 1009 "Accessible Means of Egress?"
i.e., Since the 2nd and 3rd floors are not "covered," and therefore not ADA compliant, this would also mean they are not "accessible,"
and therefore, it would appear that ICC Sec. 1009 does not apply to these floors. Is that accurate?
If all that is true, it would seem accurate to say simply:
The upper floors of a prototypical apartment building (without elevator) have no accessibility requirements whatsoever, under code.
Except perhaps as may apply to any common use areas under FHA guidelines.
Am I missing anything?
