Egress Balcony help
sd.codehelp
san diego
Is a walkway that is over a podium below grade garage considered an egress balcony? R-2, type VB building.
I have had several similar projects that this had never come up, but now I have one in plan check under 2016 CBC and the comment received was that the grade level walkway is considered an egress balcony because it is over the garage and not over grade. Would not be that bad except the walkway is in the setback adjacent to the property line.
Yes, It is four residential units that the front door exits to the side setback walkway which is over a podium garage
Not my field
But if you are at grade level?
Do you exit a unit and turn left or right or go straight to the street??
How do you get to the pubic way??
SECTION 1021 EGRESS BALCONIES
1021.1 General.
Balconies used for egress purposes shall conform to the same requirements as corridors for minimum width, required capacity, headroom, dead ends and projections.
