LGreene
I was asked about this the other day and my initial reaction was that the egress path should not go through the pool area but I wanted to check with y'all. The photos below are from a clubhouse. The space has 2 other exits, in addition to the marked exit that leads to the pool enclosure. There is also a step after you go through the door to the pool area, which seems like a bad idea in combination with the close proximity of the pool. The other 2 exits provide sufficient egress width for the occupant load. The owner would like to restrict access to the pool from the clubhouse when the pool is closed.Click to enlarge:
What would you require in order to allow the owner to eliminate the exit that goes through the pool area? Is that even allowable (exiting through the pool enclosure)?View attachment 2052
/monthly_2014_04/20140418_085902.jpg.3cb20540b6710138d400079b8b8ceeac.jpg
/monthly_2014_04/20140418_090024.jpg.2e4a6df7f3517850b2d323cdce1f255e.jpg
