LGreene
A hardware consultant sent me the attached floor plan, because he was concerned about the exit route from the rehearsal studio through the green room (I marked this door 2). The red notes are from the architect.Here's the section from the 2008 NYC Building Code:1013.2 Egress through intervening spaces. Egress from a room or space shall not pass through adjoining or intervening rooms or areas, except where such adjoining rooms or areas are accessory to the area served; are not a high-hazard occupancy and provide a discernible path of egress travel to an exit. Egress shall not pass through kitchens, storage rooms, closets or spaces used for similar purposes. An exit access shall not pass through a room that can be locked to prevent egress. Means of egress from dwelling units or sleeping areas shall not lead through other sleeping areas, toilet rooms or bathrooms.Exceptions: 1. Means of egress are not prohibited through a kitchen area serving adjoining rooms constituting part of the same dwelling unit or sleeping unit. 2. Means of egress are not prohibited through adjoining or intervening rooms or spaces in a Group H occupancy when the adjoining or intervening rooms or spaces are the same or a lesser hazard occupancy group.Here are my questions:a) Would the green room be considered accessory to the rehearsal studio and therefore the egress path is ok as long as the door to the green room does not lock?b) I've read the IBC Commentary but I'm still not 100% clear on accessory areas. Can you give me some examples of rooms that are related in function but would NOT be acceptable for egress to pass through?c) Any problem with Door 1 opening into the catering/prep area? By my rough estimate the load of this room (using 15 sf/p) is more than 49 so the doors would have to swing in the direction of egress.As always, thanks for your help.- Lori
/monthly_2012_03/572953e5a5943_TheaterFloorPlan2.jpg.506900bc4b4ebaae2ceafe5fa55ad4bf.jpg
