BSSTG
Gold Member
Greetings all,
I received the following note from a local engineer/inspector asking for some guidance. I really don't believe it would be addressed in any code.
"I called out on an inspection that a guy's fire egress window was blocked by a yard fence post and hence they could not get out of the house (about 6" out from the window). The owner's question is "how far from the window should the post be?" I said that is not mentioned in the code. Any comments or helpful wisdom."
Thoughts?
thanks
BS
Thoughts?
thanks
BS
