Electric Water Heaters
globe trekker
I have a Commercial project (an I-2 occupancy group) that is proposing to install
a new electric water heater. On the manufacturer' web site, the manufacturer lists
the particular water heater as a Residential type.
QUESTION #1: Can a Residential type of water heater be used in a Commercial
project?
Thanks for your input!
What defines the difference between a commercial or residential water heater. I can't find it in the code.
If it is just a manufactures classification then I would look at the manufactures installation instructions for approval.
mtlogcabin,
Thanks for the input! I am unable to find any differences on the manufacturer'
web site (Rheem). The normal NEC requirements for installation seem to be
compliant from what I can can read.
I saw the Residential statement on their web site and I started wondering.
It seems the Rheem commercial electric water heater is available in 208, 240, 277 and 480 voltages and 3 phase options, residential would be single phase 240 volts.
QUESTION #2: Is a physical therapy center considered a health care
occupancy, or medical (treatment) facility? RE: Article 517.2 in the 2008
NEC, Definitions.
I have some electrical physical therapy equipment for the treatment
of patients that will be installed in a new I-2 occ. group building.
Some of the equipment I am wondering about is:
(a) a light therapy (anodyne therapy) machine, &
(b) a stationary treadmill
The light therapy (anodyne therapy) equipment appears to be in question?
Any physical therapy equipment experts on here? :eek:
globe trekker said:
QUESTION #2: Is a physical therapy center considered a health careoccupancy, or medical (treatment) facility? RE: Article 517.2 in the 2008
NEC, Definitions.
The recovery rate of the hot water heater along with the voltage rating is the only difference between the residential/ commercial.
The light therapy is quite comforting for injury healing. My chiropractor uses it along with "Russian Stem" on me all the time.
I believe the main difference between residential & commercial water heaters is the manufacturers warranty. The same water heater will often have a warranty twice as long for residential use than for commercial use. Commercial water heaters are also available in 3 phase and higher wattages.
NEC, Definitions.
But that of information do you have regarding the equipment? We're both fairly conventional and common. In most cases they just use a conventional 120v receptacle for power. Neither will require a considerable amount of power (the treadmill probably will take more) and the power requirements should be listed on the device.
NEC, Definitions.
It would be considered a health care facility and part I of 517 would apply but not part II.
2009 IBC 304.1.1 Clinic Outpatient
