I have a SF residential structure with the main service breaker panel inside the attached garage. The house is rented but the occupants do not have access to the panel in the garage. If an emergency or problem arises the occupants have no access to shut off the main breaker or circuit breakers. I can't find where this is not allowed?
I'm thinking an outside disconnect should be installed but I need a code to enforce if required.
pc1
pc1
