I am speaking of electrical service drops and meters, here. It isn't in a code book that I am aware of. I ended up asking my State Electrical Inspector if a service drop and meter was considered a source of ignition per NEC, and the answer was no. I think I have only seen a gas tank set near enough to the meter once to wonder (which is why I investigated the issue).Yankee said:electrical service is not considerd a source of ignition around here (gas code requirement)
" Incinerator or Open Flame 3 feet " : 0 eeekkk!mark handler said:It's not in the NEC, local power or gas company issue. But the following is good practice
Refer to link
http://www.pse.com/SiteCollectionDocuments/builders/3885.pdf
That is assuming no leaks......................Yankee said:" Incinerator or Open Flame 3 feet " : 0 eeekkk!
I do not know the IFGC or NFPA codes that require the 3 foot rule, but I know that this is true for my area of VA also.Francis Vineyard said:The 5.7.2.3 Meter Clearances; The requirement that a gas meter be located at least 3 feet from a source of ignition waswas deleted in the 2009 edition
The gas company enforces NFPA but we enforce IFGC in Virginia
