MarkFMills
Owner has a pit floor sloped to drain into adjacent room where there will be a sump pump. Does that make meet elevator and building codes ? My interpretation is no. Because the below code states it must be in the pit. Thank you.
ASME A17.1/CSA B44 requires that all elevator pits for elevators that have Firefighters’ Emergency Operation, be provided with a drain or sump pump. The pit drainage shall be designed to remove a minimum capacity of 3,000 gallons per hour (or 50 GPM) per elevator car.
