GEe
This seems a little obscure, but here goes:
These two categories are part of 2018 IEBC 1301.6.15:
"Category b—Means of egress lighting and exit signs provided with emergency power in accordance with Section 2702 of the International Building Code."
"Category c—Emergency power provided to means of egress lighting and exit signs, which provides protection in the event of power failure to the site or building."
On the surface, it seems like both categories are satisfied by emergency lighting fixtures with battery power. But I doubt that is the intent. On the other hand, the ICC commentary seems to go too far the other way:
"Category c is applicable when emergency power is provided for means-of-egress lighting and exit signs in excess of the minimum requirements for new construction. The emergency power requirements for new construction assume a power failure occurs in the building or somewhere in the building site. It does not assume that the power failure occurs at the source of power to the site (in other words, from the provider). If the emergency power provides full protection to the site or building during power failure, Category c is applicable. Campus-type complexes or buildings that require extra security may have a power plant available to provide complete backup power for indefinite periods. This will qualify for the positive points of this category."
Complete, indefinite power is a lot more than the language of the code suggests. Thoughts?
