Emergency Lighting in Generator Control Rooms
lhughes
Supporter
A school with a roof top generator and a generator control room on the top floor and another school with a roof top generator and the control room in the basement. The generators power the exit signs and means of egress emergency lighting. Both rooms have battery operated emergency lighting in the generator control rooms. The room only has one unmarked exit and is not part of a means of egress pathway. I am trying to determine if the battery operated emergency lighting is required. These are not boiler, incinerator or furnace rooms that require 2 exits, just small 12 x 12 rooms off of the main school hallway or in the basement off of a maintence hallway. Both hallways have marked exits and generator powered emergency lighting. I have looked through the IFC and some older BOCA codes. My question is, does anyone know of any requirements for battery operated emergency lighting in generator control rooms?
maybe:::
SECTION 1006
MEANS OF EGRESS ILLUMINATION
1006.1 Illumination required. The means of egress, including
the exit discharge, shall be illuminated at all times the building
space served by the means of egress is occupied.
1. Occupancies in Group U.
2. Aisle accessways in Group A.
3. Dwelling units and sleeping units in Groups R-1, R-2
and R-3.
4. Sleeping units of Group I occupancies.
1006.2 Illumination level. The means of egress illumination
There is a requirement in NFPA 101 if the school is under a state regulatory control (like many) that use NFPA 101. Requirements exist in 101 for emergency lighting in underground or limited access structures or "portions thereof" 7.9.1.1 (2) and 11.7.3.5 (2009) Similar in older editions except numbering.
I did look in NFPA 101 and I see the section regarding underground and limited access areas. I also found 7.3.1 in NFPA 110, under lighting, equipment locations shall be provided with battery powered emergency lighting. I now have what I need to ensure the lights are required and need to be maintained. Thanks for the input.
