Enclosed pation and emergency egress
Rio
Silver Member
We have an semi asbuilt situation that we are in the process of getting permitted (contractor got caught). The contractor wants to call it an enclosed patio and we could design it that way by opening up the walls to 65% following the guidelines as set down by the city of San Diego and the CRC/IRC but after reading the below and considering where it is constructed (enclosing the front door) I thought it would have to be open; however after reading the provisions of Section R310, which covers entry doors among other items I'm thinking now that if the door to the enclosed patio is 36" wide by 80" high it will comply.
From Appendix H, patio covers
SECTION AH105
LIGHT AND VENTILATION/EMERGENCY EGRESS
AHlOS.l General. Exterior openings required for light and
ventilation shall be permitted to open into a patio structure
con-forming to Section AH101, provided that the patio structure
shall be unenclosed if such openings are serving as emergency
egress or rescue openings from sleeping rooms. Where
such exterior openings serve as an exit from the dwelling unit,
the patio structure, unless unenclosed, shall be provided with
exits conforming to the provisions of Section R310 of this
code .
2010
All opinions and comments are appreciated,
Thanks in advance,
Rio
Rio
R311.1 only prescribes travelling through garages not other types of non-habitable spaces.
With the factory made modular patio enclosure systems the windows, to comply with the 65% opening requirements, are fabricated to have all lights operable, so a slider is an XX not an XO and both are removable to provide the 65% opening. Remember you’re dealing with openings not just light.
Most of these manufacturers manufacture their windows in two heights using their own extrusions and fitting these into a conventionally constructed wall will be tricky.
Remember these are non-habitable rooms.
TJ
CA HCD did adopt Appendix H.
pete_t said:
TJAs noted above the CA state agency, Housing and Community Development, adopted Appendix H, meaning it was adopted statewide, local authorities may have amendments.
I know that, its a crap shoot
TJacobs said:
Did California adopt Appendix H?
Apparently San Diego has because when I read Appendix H it's the same as the San Diego Information Bulletin
