heartofglass
Bronze Member
Just got plans back from our architect showing a 48" work space behind a cocktail bar (space inbetween the equipment and the backbar shelving), and our bar manager is warning us that's a foot too wide (30" to 36" is standard for ergonomics - being able to reach things at the front work station and the backbar where the glassware is, etc). This is in California. I was able to find these statements below in an appendix in the 2010 federal ADA standards which SOUNDS like sometimes exceptions are made for bars. (http://www.ada.gov/regs2010/titleIII_2010/reg3_2010_appendix_b.htm)
"Several exceptions to section 206.2.8 of the 2010 Standards exempt common use circulation paths in employee work areas from the requirements of section 402 where it may be difficult to comply with the technical requirements for accessible routes due to the size or function of the area:
Common use circulation paths within employee work areas that are less than 1,000 square feet and are defined by permanently installed partitions, counters, casework, or furnishings are exempt. Kitchens in quick service restaurants, cocktail bars, and the employee side of service counters are frequently covered by this exception...
"...Machinery and equipment are permitted to reduce the clear width of common use circulation paths where the reduction is essential to the function of the work performed. Machinery and equipment that must be placed a certain way to work properly, or for ergonomics or to prevent workplace injuries are covered by this exception....
"...Nothing in the 2010 Standards requires all circulation paths in non-exempt areas to be accessible. The Department recognizes that building codes and fire and life safety codes, which are adopted by all of the states, require primary circulation paths in facilities, including employee work areas, to be at least 36 inches wide for purposes of emergency egress. Accessible routes also are at least 36 inches wide. Therefore, the Department anticipates that covered entities will be able to satisfy the requirement to provide accessible circulation paths by ensuring that their required primary circulation paths are accessible."
The bar is about 20 feet long. I'm having a hard time imagining someone in a wheelchair tending a busy bar, gathering and washing dishes, and maneuvering the anti-fatigue mats other employees need behind the bar. Or reaching the top shelf liquor. I have a disability that prevents ME from efficiently working behind the bar as well, which is why I'm the bookkeeper. :-? To me a reasonable accomodation would be having someone in a wheelchair, or someone like me, perform a different job that does NOT involve tending bar, for goodness' sake.
