Hyrax4978
I am looking to do an addition to an existing building that has an existing fire wall. A previous architect put on an addition by use of a fire wall to call it a second building. It is not sprinklered so it was the only way for them to get the added area. The owner would like another addition attached to the last addition they did. The fire wall they called out on the plans does not meet the fire wall requirements of today and maybe never should have been called a firewall in the first place. But it was. I am wondering if there is a section in the code that states that previous rated construction can meet the requirements of the day in which it was built and be kosher in lieu of needing to be upgraded to todays requirements. If A new firewall needs to be built then this small addition will not be feasible. The fire wall will also require to much work to upgrade it for todays code.
