First of all happy holidays! Hopefully you are still enjoying a break from work. I unfortunately, am not. Another problem to solve arose over Christmas day and looking for advice from you guy's and gal's. Scenario is: A fairly new (2007)Holiday Inn Express here has suffered a sprinkler pipe burst that pretty much damaged 3 entire floors with water including an elevator shaft. The existing elevator shaft was designed to be a UL listed 1- hour assembly of wood framing with one layer of type "C" 5/8" sheetrock on each side of the shaft wall. The actual finished product that was approved by my predecessor was 2 layers of 5/8" type "X" on the inner wall of the shaft. The restoration company is questioning the sheetrock replacement and whether or not they can just put it back the way it was or if they need to do more to physically achieve a 1-hour fire- rated assembly. My question to the group: Is there a listed 1 hour assembly out there that is comprised of two layers type X on one side that I can provide as documented acceptance of the original installation so they can put it back the way it was? Or if not how would you proceed? Thanks in advance. Eric
