BayPointArchitect
Sawhorse
I am currently designing a sports bar with a roof top deck and new stairway leading through the restaurant below. This project is located far outside my jurisdiction and the AHJ has not responded to this same question. My client would like the stair to be open and visible to the main floor so that people get the idea that there is an inviting space upstairs. The upper level seating area would be 700 S.F. and limited to 48 occupants. I know that the basic answer is that a second story requires two exits with at least one exit being enclosed. My effort is apply every other limitation possible to have only one stair exit. http://www.fileden.com/files/2007/3/25/925948/OpenStairQuestion.pdf.
Questions:
1) Can the stair be open to the interior of the restaurant below? If not, then may it be a simple smoke proof enclosure with only a door at the top of the stair? Or does the stair need to be fire rated stair enclosure?
2) Can the stair landing also serve as the entry vestible for the restaurant below? Or does the exit from the roof top area need to be separated completely from the restaurant? In other words, do patrons need to exit the building and then enter again through a separate exit? I am thinking a common landing/vestibule is okay.
Local codes: 2006 IBC and 2000 NFPA
Thanks
AIA, NCARB, ICC, NCOA, CSI
ICC Plans Examiner
Questions:
Thanks
ICC Plans Examiner
