The situation is NFPA 101 is enforced which brings NFPA 220 in as well.
In type I to IV construction, exterior bearing walls shall be of approved noncombustible or limited-combustible materials per section 3-1 thru 3-4. In order to meet building codes and energy codes, exterior walls include weather barrier and insulation that are combustible. Is there a acceptable/approvable way to include these combustible weather barriers and insulations in the exterior load bearing walls?
It is my understanding that NFPA 285 test pass is applicable to non-load bearing exterior walls only (for NFPA enforced projects only).
