syarn
Silver Member
stayed in an indianapolis, indiana marriott courtyard inn over the holiday during the annual in-law visit;
it was a 3 story hotel probably close to 70,000 sf total and looked to be IIB; conc plank floors/ceilings;
at all floors - in addition to the typical sliding elevator cab door there was another fire rated swing door flush at the framed opening into the elevator that was held open about 180 degrees by a what looked like a mag type hold open...which probably released if the fire alarm system was activated...so in essence you had two sets of doors at each floor for the elevator - an outer corridor swing door and the inner elevator cab door.
is this the typical way to fire rate the elevator door opening or can the cab door be the opening protective?
what IBC 2006 code section is this?
