Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,318
Admittedly, this is way outside my level of expertise, but this FAQ from the NFPA on lithium fire safety is supposed to clear up some confusion, but it confuses me.
I underlined something that caught my eye in the FAQ's, I have pasted the relevant parts below. On one hand it says lithium fires happen because the lithium in the batteries is exposed to water, on the other hand it says fire is adequate as an extinguishing agent because the type of material in a battery isn't the kind that ignites when exposed to water.
What is my misunderstanding?
How do fires from lithium-ion batteries start?
Lithium-ion battery fires happen for a variety of reasons, such as physical damage (e.g., the battery is penetrated or crushed or exposed to water), electrical damage (e.g., overcharging or using charging equipment not designed for the battery), exposure to extreme temperatures, and product defects.
Once the batteries catch fire and water is applied to them, does it make the fire worse because lithium in the presence of water creates combustible hydrogen?
Firefighters should use water to fight a lithium-ion battery fire. Water works just fine as a fire extinguishing medium since the lithium inside of these batteries are a lithium salt electrolyte and not pure lithium metal. Confusion on this topic stems from the fact that pure lithium (like what you see in the table of elements) is highly reactive with water, while lithium salts are non-reactive with water.
