I believe you are correctI thought the window flashing tape was to be directly on the sheathing?
It is on the sheathing, at least at the top.docgj said:I thought the window flashing tape was to be directly on the sheathing? I was told that any moisture that gets behind the house wrap will run down and follow in the top of the window. This info came from a class hosted by PHRC.docgj
What is it that you take issue with?Bootleg said:The window in the photo isn't flashed correctly it will leak.
Hi Tim,TimNY said:My personal opinion is that if you place flashing over the bottom fin you are making an assumption that water will never enter behind the window.If that is a safe assumption I don't know why you would bother with the sill pan.
