Fire apparatus access road dead end/turn around
beach
Gold Member
The SoCal Beach
IFC Section 503.2.5 Dead ends. states that dead end fire access roads in excess of 150' are required to have an approved turn around area, the 2006 Code and Commentary gives a pretty good explanation as to why (backing out large vehicles, etc.) My question is where did the 150' number come from?
My gut feeling is:
1. Slower response due to emergency vehicle making wrong turn and having to back out. (150' is a reasonable distance to back in a timely manner?)
We are in the process of finishing up our local amendments and the Chief posed the question as to where they came up with 150 feet max. length.
any input is appreciated
maybe 150 preconnect?
as in reach all portions of a building with 150
503.1.1 2009 ifc
so if you set on the street you can strech the preconnect and still reach all portions, otherwise give me a fire lane
well i read the commentary just now and that is what it says and even shows a pretty picture of the idea
When I brought up the pre-connect theory, I was asked this: "Lets say we have a public street with a 300' dead end, and there are no buildings on this street. Is a turn around required?"
My answer was yes, because the code requires a turn around when the dead end is over 150' feet, it doesn't mention if the street has buildings around or in the vicinity of it.
Then I was asked where the 150' distance came from.....why not 100' or 200'?
So..... my next best guess so far is that the apparatus would have to back out if it mistakenly went into that dead end on an emergency call, which would affect response time because it would have to back out.... and possibly anything over 150' was not reasonable
I think access to buildings/facilities and dead end turnarounds are two different things
Ok now the chief is talking monkeys and uncles
Most cities have regulations for public street design, and should include turnaround, dead end provisions
Let heffe know that the streets are not only for the big red trucks but other traffic such as trash trucks tractor trailers etc
Where there are private streets or shopping centers or such non public streets I take it the fire code more applies
And once again the road yes is designed for ease of firefighters but also other vehicles
beach said:
Good point!
Hay the clock hits twelve every so often
Good luck
So what does heffe want to push it to?
This is why fire prevention should be a mandated position for three or four years before you are a heffe
And I guess he does not have to pull hose anymore
