Fire Door Label Covered by Continuous Hinge
LGreene
San Miguel de Allende, Mexico
When an existing door has a hinge problem, it's common practice to replace the original butt hinges with a continuous hinge (aka piano hinge). When a UL listed continuous hinge is installed on a fire door, it often covers the existing fire label. What should a facility do if they need to make this repair? Would you require UL or Intertek to field-label the opening (very expensive), or is there a way that the facility could document the existence of the label that would be acceptable to the AHJ? If a new door is ordered for use with a continuous hinge, the label is typically installed on the top of the door and the underside of the frame, but in most cases it's not physically possible to move a label, even if it was allowed.
I doubt, in such cases, a piaon hinge is necessary the full height of the door. Why not cut out part of the flange to expose the label.
Or have a duplicate label installed over the hing flange.
lunatick said:
I doubt, in such cases, a piaon hinge is necessary the full height of the door. Why not cut out part of the flange to expose the label.Or have a duplicate label installed over the hing flange.
I don't think the cutout would be allowed on a listed hinge for a fire door.
I think that field modification to a fire rated door and fire frame assembly, would require a field visit and certification of the finished product. The other question that I would have is what does the door manufacture or the manufacture of the fire rated door frame allow to be installed on their product? I don't think many of them actually use piano hinges for testing of the product(s).
Yeah Bob, The whole thing is an assembly, and the rating includes all of the components as tested. Changing the hinge may not seem like a big deal but...
fireguy said:
door hinges are listed? Are the fasteners also listed?
Continuous hinges that are UL listed bear a label (usually an embossed mark). Butt hinges are subject to the requirements of NFPA 80 when used on a fire door but are not required to be individually labeled. The hinges must be installed with the fasteners they're shipped with.
It will likely vary from jurisdiction to jurisdiction but, we would accept a photo of the original plate and a wide angle with the plate in view.
