LGreene
Sorry - 2 questions in one day that I need help with.  I recently received a question about why doors with fire exit hardware don't open during the hose-stream portion of a fire test (or when hit by a hose stream in an actual fire).  The reason is because the latching hardware basically fuses in the latched position when heated to somewhere around 1000 degrees, depending on the component.
I posted about it on iDigHardware, including a photo of fire exit hardware after the fire test. Someone asked how this affects firefighter access. I wouldn't think that at that point the doors would be expected/needed to operate normally, but I'm wondering if any of you have experience with this.
The information is here: https://idighardware.com/2018/09/fire-door-latching-after-the-fire/.
Thanks!
- Lori
Thanks!
- Lori
