Fire Protection Reduction
John N. Crittenden
Minturn, Colorado
Doe anyone know offhand if the reduction of fire protection rating for R construction based on sprinklers applies even if the sprinklers are also used to allow areas increase for VN Construction. i.e., from 1-hour to 30 min.
I am concerned about the room to room separation for R construction.
John,
Assuming IBC (not IRC) and 5B for VN, a reduction is permitted with an NFPA 13 (not 13R)
708.3 Fire-resistance rating. Fire partitions shall have a fire resistance rating of not less than 1 hour.
1. Corridor walls permitted to have a 1/2 hour fire-resistance rating by Table 1018.1.
2. Dwelling unit and sleeping unit separations in buildings of Type IIB, IIIB and VB construction shall have fire-resistance ratings of not less than 1/2 hour in buildings equipped throughout with an automatic sprinkler system in accordance with Section 903.3.1.1. (NFPA 13)
711.3 Fire-resistance rating.
Exception:
  • Like
Reactions: JBI
What kind of building
House apartment townhouse other??
I'm leaning the same way Francis is. Sounds like a hotel/motel question as the OP indicates 'room to room'.
And I agree with Francis's assessment as well.
The other key to the question was the area increase aspect, only a full NFPA 13 system provides increased area. A 13R would only allow the height increase.
The sections I quoted above are from the 2012 edition. The table 503 is easier to read in the 2015 IBC. T504.4 for stories and T506.2 for areas are self explanatory with the footnotes.
  • Like
Reactions: JBI
