We had the project kick off meeting there was one question that didn't get real clear answer, I wanted to see if there was any documentation first.
The Diesel Pump that we are installing; the wet seals drip about 10 gallons of water per day. We have been trying to determine whether this catch basin for this water can be ran in to the storm water drain, sanitary line, or if it needs to be captured and treated as waste water. Said water coming out of that pump is supposed to be as clean as the potable water going in to it.
I know the diesel tank is a double wall tank with a sensor to help protect against a contaminating spill. I would rather not have to manually pump the water out of that hole every day and Pioneer thinks that the closest sanitary line (over 300’ away) is not deep enough to run the line across to.
Can anyone please supply me with documentation that shows I can run this drain into the storm water safely?
