So we're renovating an old house, and based on the use it requires the floor over the crawl space to be 1/2hr rated per the architect. The building is sprinkled. I've read over the IBC several times, and I found where if the rating is 1hr or less in a sprinkled building, fire dampers are not needed in a "wall". It doesn't say floor or fire barrier or rated assembly or any of that. It specifically says "wall", which frankly doesn't make much sense to me. I don't have the commentary available to check the interpretation so I'm kinda stuck. Do I really need radiation dampers or fire dampers at my residential style floor registers? I can't for the life of me find a manufacturer that make residential style floor registers with rad dampers either.
Thanks in advance!
Thanks in advance!
